caesar II general questions
Hi!, I am not so familiar with Caesar II, But I have some questions:
1-after running the program how can we change the supports to reduce the nozzle loads.
2-when we assign the friction coefficient to +y restrictions, then the program will start nonlinear solution and it will take long time, is that possible to neglect the coefficient for +y restrictions?
3-is that possible to model the PRV in CAESAR II or not.
Thank you
Thank you
RE: caesar II general questions
1 - Use experience
2 - depends if friction is important or not.
3 - yes
