Possible Code Case for N04400 Welded Pipe
I have several heat exchangers that we are fabricating from N04400 materials. I am wondering if there is a code case availalbe for ASME Section VIII Div. 1 that would allow us to order welded pipe. Section II only lists the seamless.
Thanks for your help.
RE: Possible Code Case for N04400 Welded Pipe
