Tube sizing
Tube sizing
Tube sizing
Hi Guys,
Can anyone take a look and comment on the attached spread sheet intended for sizing tube for basic low speed drive shafts. Just want to make sure i haven't missed anything. (intended application is to pin the tube between motor and valve shaft)
Cheers
Kieran
RE: Tube sizing
Yes i will be using 2 x HBK spirol pins 90 degrees to one another. i've also sized these on the output torque of the motor using T=Fd with F being the double shear strength of the pin and d the diameter of the shaft.
