Import System.IO
Import System.IO
hi
I have some journals that containes the "Import System.IO",
and they run without any problems on Win XP.
But now I have gone to Windows 7 ,
and NX crashes when I run a journal with "Import System.IO"
( I use this command because I do some file-manipulation
in the journal ... >>if not File.Exists.....)
I use NX 6.0.5.3
I use NX 6.0.5.3
RE: Import System.IO
Can you possibly post more of your code?
Also, what type of windows 7 are you running (64bit, or 32bit), and is this different than the xp version you have had success with? What version of NX are you running (64 bit, or 32bit)?
I imagine that you were also running NX 6.0.5.3 on the xp machine as well, right?
One last thing, have you looked at your log file to find out the error message that NX gives, and if so, can you post it?
Look forward to your response...
sumBuddy (Mechanical)
"I would like to change the world, but I can't find the source code."
1.I attach the journal. ( please edit the extension to .vb again.
2.Nx 6 version is as you said 6.0.5.3 - running on xp 32 bit.
3.windows 7 is running on a 64 bit and nx is 64 version.
4.I havent looked in the log file yet - I´ll do that on tuesday when I´m back at office.
lklo
PS. If you run the journal , remember to set the environment variable in your env file or startup bat file:
PRODUKTIONS_DIR=Z:\Output_dir_DWG\
