Refile > Load No Components
For refiling (NX4 > NX6) we want to enable a revision rule which should "Load No Components", so assemblies will be "quickly" retrieved and saved by refile process.
Question: has to make sure that refile process is using this revision rule?
any tips?
any tips?
RE: Refile > Load No Components
This can all be done from the...
File -> Options -> Assembly Load Options...
...in the last section of the dialog labeled 'Saved Load Options'.
Once a new Load Option file has been created (the default name is 'load_options.def') and if you want everyone to use the same one, just set the environment variable:
UGII_LOAD_OPTIONS=<path to and including the load option file name>
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
Yes we are using refile utility.
Setting the UGII_LOAD_OPTIONS works
