Solidworks Custom Properties into Inventor
hi guys. I am a Solidworks User for about 6years. I have a customer want all drawings into Inventor software with Iproperties.
It is possible to convert Solidworks to Inventor with Custom Properties? I tried to use transmagic software still the custom properties not linked. Please advise
Thank you
Aldrin Salvatierra
Mechanical Engineer/Project Coordinator
Thank you
Aldrin Salvatierra
RE: Solidworks Custom Properties into Inventor
The limitation is that only general properties are available, not configuration-specific properties (though it sounds as if you do have access to SW, so you can get around that).
It would be great if you can give me details of the procedures having Windows API to access custom prop.
I have option to save BOM from Solidworks into Excel, from that i can create an i-logic for auto-generation of i-properties into Inventor. I think this windows API could be beter.
Kind Regards
Aldrin Salvatierra
Kind Regards
Aldrin Salvatierra
www.solidengineeringph.com
http://lmgtfy.com/?q=dsofile
