Windows installer error and NX 7.5
This is probably more of a windows issue than anything to do with NX but perhaps someone here has had the same issue and knows of a fix:
Running Windows XP SP3 32 bit:
When I single click on a NX part file windows installer immediately launches and says it is configuring UGS NX 7.5. The window says "gathering information" for a 20 seconds or so and then I get a window saying "The feature you are trying to use is on a CD-ROM or other removable disk that is not available. Insert the disk and click OK." I click cancel and I get another window that says "error 1706. No valid source could be found for product UGS NX 7.5. The Windows Installer cannot continue." I click ok, the window closes, and I go about my business as if nothing happened.
This has happened about 5 times today. It just started happening. I was using 7.5.3.3 and had been for months without any issues. I upgraded to 7.5.4.4 mp.02 today to see if that would fix anything and I still get the same behavior.
Any ideas?
Thanks in advance.
RE: Windows installer error and NX 7.5
Please contact GTAC.  They should be able to help.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum:   http://www.plmworld.org/p/cm/ld/fid=209
