How to delete REFERENCE_COMPONENT
Hello!
How to delete this REFERENCE_COMPONENT attribute in NX 7.5, I have problem when i have insert one more assembly in existing assembly, it wont show me new assembly in 2D. thank you very much. bye
P.S. X (delete) down right is not solution (in my case ) :)
RE: How to delete REFERENCE_COMPONENT
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
John R. Baker, P.E.
Industry Sector
Cypress, CA
I have made one assembly( and its 2D drawing), and the drawing is approved.but now we want to show assembly on which we mount existing assembly also in 2D. so i have open 2D, went to modeling and there i have inserted that other assembly.and i can't get it in 2D. I did the same stuff with one another assembly where i have use same assembly as reference, and there all went fine (i get it in 2d), and only difference is that properties "REFERENCE_COMPONENT".when I click on part in 2D.
Sorry for little confusion explanation
You say you "inserted" another Assembly into your drawing. How did you do that? What steps did you perform when you "inserted" the new assembly into the file?
Also, you keep referring to 2D. What do you mean by 2D? All NX models are 3D. Is this a 2D wireframe model created in some other system?
John R. Baker, P.E.
Industry Sector
Cypress, CA
2.I have went to modeling and there i have all functions as in assembly mode, and there inserted and constrait it.
3.Under 2D i ment drawing made form 3D model, but drawing which is in its own file.
John R. Baker, P.E.
Industry Sector
Cypress, CA
John R. Baker, P.E.
Industry Sector
Cypress, CA
