Turn off constraints display when dimensioning.
Hi All
I would like to use ampardim to place a new dimension on a profiled sketch without having all the existing constraints display.
I believe in MDT4 there was a system variable AMCOND which you set at 0 to achieve this but it does not apparently apply in MDT6 and I am unable to find any other way.
Thank you in advance,
Aussie John
Aussie John
RE: Turn off constraints display when dimensioning.
Hope this helps.
Thanks for replying Fred Garvin. As it so often happens I tripped over the answer to my posted question after giving up and getting on with something else.
AMCONDSP (0 or 1) to control constraint display coming on when dimensioning a sketch (with ampardim). Note this was not listed in the MDT 4 help index but it works all the same.
Others I noted at the same time:-
AMCONDSPSZ (1 to 19 default is ~5) to set size of displayed constraints. Quicker than from Menu!
AMVER (generally known) and the more extensive lesser known AMVERALL to see your MDT version/build/patches.
Best to all,
Aussie John.
