CWI stamp - is it now required by D1.1 for welder certs?
I recently read thread725-241866: CWI Stamp: CWI Stamp in order to answer this question but I need an answer based on the newest version of the Code.
It was my understanding from previous versions of D1.1 that a CWI does not have to stamp certifications signifying that a person is qualified to weld, at least not in the motor vehicle sector. We use CWE's to train but the actual results of the plate bend test or coupon destructive test are not stamped by a CWI.
I was contacted by a customer a few days ago who told me that the latest version of D1.1 requires a CWI stamp to show that a welder is indeed qualified to weld, and they are requesting that all of our welders have a CWI stamp on their welding cert.
Since I only had the 2006 version available I contacted my welding trainer in order to verify this change, and their CWI sources replied similar to the 2009 thread that the stamp is not required. I understand if the customer's purchase order requires the stamp, but if anyone is aware of any changes to the Code I would appreciate it. Thanks!
RE: CWI stamp - is it now required by D1.1 for welder certs?
"An individual who, by training or experience, or both, in metals fabrication, inspection and testing, is competent to perform inspection of the work."
The day D1.1 starts making a CWI mandatory for welder quals as part of the Code is the day that any knowledgeable customer starts invoking Section IX in lieu of D1.1 for welder qualifications as mandatory (which is already permitted by D1.1 with Engineers approval anyways, and very common practice.)
Some of our customers do require (by contract) that testing be performed by an AWS CWI.
It makes me "feel better" when I see a WQT -- welder qual -- that was given the Visual inspection by a CWI. But a WQT properly completed and certified soley by the company hiring the welder is fully acceptable. Unless there was a clause in the bid/job specification, or in the contract, there is no "basis" for rejection of that WQT certification.
Now I am sure third party involvement is a necessity. Thirty years as an inspector has made me a cynic. I was recently visited a shop for an unrelated matter when I witnessed the mechanical contractor qualifying several pipe welders. The shop "QC" inspector would prepare the bend straps, bend them, and then grind out any small surface defects and pronounce the welder qualified. Need I say everyone passed the test?
Best regards - Al
That "rumor" never came to fruition but continued long after I let my CWI certification lapse. Similar was true of ASNT Certification for NDE/NDT. I became an ASNT Level III, also in anticipation of future need/requirement.
