stiffness calculation in ansys
hai friends
       i'm using ansys for my FEA. now i want to calculate the stiffness of the membrane which is placed in the coupling. how to calculate the stiffness value of the membrane.
regards
spy_shell
RE: stiffness calculation in ansys
You are going to have to more clear on what you want...ANSYS should calculate the stiffness properties for you assuming you give the appropriate dimensions and material properties.....
