Auto Explosion without assembly constraint
I know that auto explosion work with assembly contraint but is it possible to create a sample vb to do the following ?
- ask the user to select
         - some components in a specific order
         - select an axis
- ask the user to type a distance value
- have each component shifted by the same value
Does anybody have already done this ?
TIA
Didier Psaltopoulos
http://www.psi-cad.com
RE: Auto Explosion without assembly constraint
Yes.
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
Did you have this kind of programm ?
Didier Psaltopoulos
