Hiding a Menu Item
Hiding a Menu Item
Hiding a Menu Item
I'm looking to hide the File->New option.
Using a custom MEN file, I can add the line "HIDE UG_FILE_NEW". And that works.
But, how to also hide the toolbar icon ?
NX 6.0.5.3 (NX 8 Testing)
Windows XP32 (Windows 7 64)
RE: Hiding a Menu Item
RMB on the toolbars - choose customize - now right mouse button the file new button - delete.
Of course a user is able to insert the command again, i dont know if its possible to permantly remove the file-new button?
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Why, pray tell, are you trying to HIDE the File -> New... menu and icon?
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum:   http://www.plmworld.org/p/cm/ld/fid=209
We're implementing a PLM solution and we'd prefer users to create new files within PLM.
Obviously the PLM solution has a file new option (inside NX), we'd just prefer to ensure that that's the option the user uses.
Rather than hiding the File -> New... menu itme, why not just change the 'default action' to call your custom application.
This can be done using something called MenuScripts.
Note that while MenuScripts was the mechanism we used before we added the Customize tools to edit the Menu and Toolobar items, it still can used today, particularly for something like what you're proposing, changing what a menu item does, or adding a pre- or post- action to a menu item.
If you go to NX Help and search on 'menuscript' you will find the information that you need to set this up.  The big advantage of using MenuScripts over using only Customize, is that it's easier to prevent the average user from undoing this since it's done at a level where the changes are made to NX as it starts up so as far as the user is concerned, this is how NX is supposed to work and he will never know the difference as long as you don't give him WRITE access to where the 'MenuScript' files are located.
Anyway, long term for something like this, MenuScripts are the preferred approach.
John R. Baker, P.E.
Industry Sector
Cypress, CA
You're correct, that would be a better solution.
Thank you.
