Flushing Water Mains - Scouring Velocity
What velocity would I look for to achieve a proper scouring in a water main? 2.5 ft/s? 5 ft/s?
Any links?
Thanks!
Any links?
Thanks!
Flushing Water Mains - Scouring VelocityFlushing Water Mains - Scouring Velocity(OP)
Any links? Thanks! Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesThe world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
Engineering-centric businesses face a number of challenges today, but unmanageable design and change processes don’t need to be counted among them. Download Now
RE: Flushing Water Mains - Scouring Velocity
http://www
A typically flushing velocity of 3.0 to 3.5 ft/ sec will normally suffice.
For example an 8-inch main at 3.5 fps will give you a flowrate of 548 gpm, which is fairly easy to get rid of. For an 18-inch main, 3.5 fps will give you a flowrate of 2775 gpm, which becomes more difficult to dispose of.
It is not always practical to get scouring velocities is larger pipes and you may have to live with the fact that there may be some sediment in the pipe. This is why it is very important that the pipes are kept as clean and free of debris as possible during construction or repair.
Minimum flushing velocity per AWWA C651 is 2.5 fps so 3.5 fps is a good target for public mains. There is a table in the standard that indicates flows needed for 2.5 fps and the size/number of taps needed at a pressure of 40 psi.
For private fire mains, flushing velocities may potentially need to be 10 fps or higher (about 1,560 gpm vs 400 gpm for 2.5 fps).
No direct links, but you can do a search for "AWWA C651 Flushing" and find specifications or guidance documents referencing C651 for the stated flushing requirements. For private fire lines, NFPA 24 is available for viewing if you register (free) at the NFPA site.
