Siemens S7-1200 relay problem
I have problem with hanging relays in S7-1200 main CPU unit.
After a couple of weeks on and off (30sec)with a small load my outputs starts to hang.
I have seen this on my two instalation and it looks like bad quality on the used relays in the CPU.
My load is a EXx saftey barriar 9176 fron Stahl, data sheet added to the thred.
Cant see any reason for this problem, please help?
RE: Siemens S7-1200 relay problem
Are you turning on/off the relays using any counters? If so, then check if the counters are reaching their maximum values.
My load is non inductive and only 60mA
On and off 30s,
starts to get problem after a couple of week usage
BTW: Is it Johan?
Gunnar Englund
www.gke.org
Im using a safty barrier directly connected to the PLC.
EXx ia
Where are your systems? Anywhere near me?
Gunnar Englund
www.gke.org
Do you still have skype
I will visit Braviken soon. Is that where your system is? I have just bought a fast contactless current probe (5 MHz 10 mA-20 A) that may come in handy.
I can pop in and have a look when I go there. Won't cost you a dime - but you'll have to buy me lunch or dinner.
Gunnar Englund
www.gke.org
Give you a call tomorrow
/Johan
Gunnar Englund
www.gke.org
