Aluminum Elongation for 3004 H22
We are looking at an application of subsequent forming of aluminum tubes, 3004 alloy, H22 temper. Where can I find elongation data for this material?
The approx geometry will be about 6" diameter x .030 inches thick wall (before forming).
If needed, can we anneal the part before forming to the O condition to provide better elongation for forming? Or can we increase formability some other way?
Thanks.
Thanks.
RE: Aluminum Elongation for 3004 H22
How are the tubes being manufactured? Is the raw material 0.030 inch thick 3004-H22 that is subsequently rolled into a tube shape? Or something else?
ASTM B209 is the North American standard for Al sheet. The requirement for elongation in a 2 inch gauge length specimen is 3% minimum for a thickness of 0.030 inch.
