Importing Results When Translator Doesn't Recognize Output Variables
Hi all,
I'm trying to import some Abaqus results into NX 7.5
The model I'm working with is a random response done in Abaqus 6.9.1, and NX 7.5 does not recognize the root mean squared results sets (RS, RE, RU, RV, RA, etc). Since I don't have access to Abaqus/CAE, I'm not sure how I can view these results. The model is too large to just print the results to a text file.
I'm wondering if there's a way I can use the scripting functions in Abaqus to manipulate or rewrite the results into a neutral file so that NX will recognize them.
Anyone have any ideas?
Thanks for the help.
RE: Importing Results When Translator Doesn't Recognize Output Variables
Mark
Mark Lamping
CAE Technical Consultant
Siemens PLM Software
It's a MD nastran example from the Dynamic Analysis User's Guide made in Abaqus 6.9.1.
Note, only RMS type outputs are requested in the *.inp file.
Also, I read the input file into NX 8.0.1 and 20 entries weren't recognized... all related to the random steps:
| UnSupported | 20 |
| *PSD-DEFINITION | 2 |
| *RANDOMRESPONSE | 3 |
| *GLOBALDAMPING | 3 |
| *MODALDAMPING | 6 |
| *CORRELATION | 3 |
| *BASEMOTION | 3 |
So it's not a complete surprise NX is confused by the random results too.
Mark
Mark Lamping
I realize this is an area that hasn't been fully implemented in NX, but this is the format I was given to work with so need to find a work around.
To that end, I think I'm almost there...
In this thread I'm looking at making an Abaqus script to add a step to the ODB file and change the 'RS' resutls to 'S' results.
http://www
It seems to work when I view the operations in the python terminal, but NX doesn't recognize the newly added step when I import the results file
If you feed me example ODB files, I can continue to pass them to development for their review with the goal of short term and long term resolutions. Short term being the ability to read the converted data, and long term being the ability to fully support random pre/post processing with Abaqus.
Mark
Mark Lamping
I suggest that you submit an enhancement request with GTAC and reference my response here. That way you will get notification when the enhancement is complete. Report an issue to GTAC through this link or call them:
http:
Your example model was a blessing and very much appreciated. It made the turnaround with development easy.
Mark
Mark Lamping
