100mm spaced grid lines with X,Y,Z values listed in each view
i have a grip file (grid.100.grx) that worked perfectly up through NX4. NX5 it kinda worked. NX7.5 it does not work at all. Does anyone know of way to fix this or a new method? thanks.
RE: 100mm spaced grid lines with X,Y,Z values listed in each view
check if prefereances > grid & work plane does what you need
That being said, if this is the program I think it is, is was written before we made a series of changes (first available in NX 5.0) to the Modeling and Drafting 'Grid' functionality adding the ability to display lines in addition to just points and also adding an option to label the major grid lines. To use this built-in functionality, go to...
Preferences -> Grid and Work Plane...
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
John R. Baker, P.E.
Industry Sector
Cypress, CA
As far as I know, the toolkit programs were only distributed as executables, no source code. Someone at EDS might still have the source code, but getting them to release it might be as painful as having all your teeth pulled in one day.
Ben Loosli
Grid lines on the drawing help when parts are designed in vehicle position.
