Submodeling from substructure results
I need to use submodeling driven by substructure .odb file.
I've created substructure which has 13 dofs from 64-node simple model. Analysis of substructure works properly, and writes results to .odb file.
When I'm trying to use this .odb file as a bc's input file to node-based submodeling, Abaqus returns error message:
No valid element types for submodeling interpolation were found in global model
Does anyone has used these methods together?
Any help would be much appreciated
Tomasz
