Macro for convert old constraints to Assy Constraints
Hello everybody,
i've recorded a macro that convert the old mating conditions into the new assemblies constraints, closes all the windows (info window, assembly constraints window, etc...) , then in the ant toggle the display constraints to OFF (both of them).
The problem is that i did this in a specific part and now if i playblack the macro in another part, i get an error on that the macro cannot find the specific part.
Is there a specific attribute that i can fill in in the macro so that this is valid for all our parts?
I've attached the macro, in the last two rules you will see 7204-000-1672/1-03 and this should be changed into something so the macro is excecutable independ of the filename.
Is this possible?
Many thanks!
Is this possible?
Many thanks!
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
RE: Macro for convert old constraints to Assy Constraints
Best regards,
Michaël.
to use the comandline utility refile_part to do this?
Best regards,
Michaël.
