GE D200 point check
GE D200 point check
Is there a better way to check config file for GE D200?
After I update point list it takes me forever to check whether other points are still OK (I'm doing it manually).
I just need to compare old file with the new one to see changes.
RE: GE D200 point check
If you only need to compare files, plenty of diff programs out there...
Dan - Owner
http://www.Hi-TecDesigns.com
Problem is that configuration is saved in some 700 files some of them database files, some files are custom format...
