Hydrotest of Pressure vessels
Dear Members
Would like to know if hydrotesting of ASME Coded vessels ( VIII Div 2) can be done for more than one vessels together.( 2 vessels in our case) The hydrotest pressure is same and vessels are identical.An interconnecting hose will be used to connect the vessels. Is there any extra precaution to be taken?
Thanks in advance
Sree60
RE: Hydrotest of Pressure vessels
When it's leaking then you know whitch vessel it is.
Greetings
sree60
