solid edge sketching error
I'm running solid edge version st2 (102) on windows xp. I started making a sketch in a par file, and found that an error displays next to that sketch in the pathfinder(red exclamation mark). The text of the error is "Internal Error: The feature generated results in a geometry condition that is not supported by the system." To create this sketch, I copied outlines from an assembly file, and pasted them into this sketch in a par file. Does anyone have an idea why this is happening?
RE: solid edge sketching error
Could be ovelapping lines or something like that.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
In 2D drafting it doesn't matter - and from what I've seen over the years many 2D draftsmen don't care either if there are overlapping lines.
Overlapping or crossing of lines is allowed in some special cases in a sketch (eg draw 2 overlapping circles and you can extrude them both at the same time), but generally try to avoid it.
bc.
Quadro FX4600.
Can you post file with the sketch?
bc.
Quadro FX4600.
Not entirely sure why, but could that be it?
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
FAQ562-1410: I'm having trouble with sketcher (SOLID EDGE ROBUST SKETCHING TIPS)?
