Teamcenter_multisite issue
Dear ALL,
I have setup a multisite env between three sites and when we are trying to do an remote export from one site to another I get the following error message
"The correct version of schema transmit file cannot be found. Verify that the POM_TRANSMIT_DIR environment variable is set correctly and that a transmit file exists for the site/schema version."
I have also done the install -gen_xmit_file to generate the sch and shared the same between the sites, but still do not get the result and face the same issue.
Vilas
Vilas
