convert multiple parts to single dxf for water/laser cutting
I've designed a frame using SW2007. In Solidworks, I've got an assambly, which consists of several plates (parts), which are slotted togheter. I'd like to produce this frame using water or lasercutting.
Therefore, I'd like to have a file (.dxf format) with all the seperate plates (parts) laid out in one plane, which can be loaded into the cutting machine so the machine can cut all the parts of the frame from a single plate.
Is there a quick and easy way to put my parts into this dxf file?
Thanks, Mike
Thanks, Mike
RE: convert multiple parts to single dxf for water/laser cutting
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
When I put the assembly into a drawing I have a 3D picture, while I want a 2D picture (think of flatpack furniture: I don't want the finished cupboard (3D), but all the sides, shelves etc. laid out in one plane (2D), so I can cut it out).
Cheers, Mike
Insert > Drawing View > Model
Anna Wood
SW2011 SP4, Windows 7 x64
http://www.renderbay.com
http://www.solidmuse.com
http://www.phxswug.com
Mike
