Partial Bolt Hole Circle Centerline
I am trying to create a partial hole centerline in ST2.
The problem is that when I use the Bolt Hole Circle command to insert the centreline, it creates a full bolt circle.
The part to be dimensioned is a plate that looks like a segment of a circle and thus the holes are on a PCR.
Is there a way of breaking the centreline or an option to create a partial centerline?
I have tried using the add/remove elements command in the centreline command and I have also tried splitting the centreline.
Any feedback would be much appreciated.
