Pattern Edge Blend
Pattern Edge Blend
New user here just switched from SW.
I have a tube with a flange and a rib that has edge blends on it. I can do a circular pattern on the rib but is it possible to pattern the edge blends as well?
Thanks in Advance.
Chris
Thanks in Advance.
Chris
RE: Pattern Edge Blend
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
The edge blend is on the "feature" toolbar therefore it is considered a feature, and using instance feature seems like it should work. To a SW user that is.
Sorry John, I'm on NX7.5
While I do respect the logic of thinking in terms of what you know, don't forget parent/child relationships - the blend doesn't exist without the rib, therefore cannot be arrayed without the rib.
Instance Geometry might work in this situation as well.
Tim Flater
Senior Designer
Works really well in most cases.
