Shaft Grounding
Shaft Grounding
Shaft Grounding
We just installed a VFD Yaskawa AC Drive-A100 on a wire drawing machine
I´ve read that we need to ground the shaft to avoide damage to the bearings cause by leaking currents through them
My question is: Isnt the shaft already grounded through the gear train? The shaft has a steel gear directly couple to it and the machine structure is already grounded
RE: Shaft Grounding
No.  Gear teeth and bearing balls both are normally separated from mating surfaces by a hydrodynamic oil film, which is thin, but insulating.
Mike Halloran
Pembroke Pines, FL, USA
RE: Shaft Grounding
As Mike says. And it is when capacitively and inductively coupled voltages discharge through those insulating films that you get EDM (Electric Discharge Machining) in your bearings.
There is no cure-all for this. You have to find out if the situation is bad or not and then what the dominant coupling mechanism is. After that, you can decide if you need to do anything about it and also what to do.
Gunnar Englund
www.gke.org
RE: Shaft Grounding
Hello Lukin1977
Use a proper motor with insulated bearing or install a brush for shaft earthing. The VFD applications requieres an Inverter duty motor  usually this kind of motor are prepared for it and some one have an insulated bearing in N.D.E,  could be good you consult with your motor dealer.
Carlos
RE: Shaft Grounding
The VFD was intalled on and old machine and the motors are old too. So they are not inverter duty motors.
Skogs: Are you saying that grounding the shaft it is not always necessary and it depends on case study? Sorry my english is not very good
