ST3 Re-attach dimension problems.
Using ST3 SP6 on Windows 7 64-bit.
I keep getting problems re-attaching dimensions after drawing view updates. Individual dimensions will attach OK but others that are part of a string or stack seem to go all over the place, and sometimes disappear completely.
When they disappear the view dynamics (element drag) seems to get switched off. Elements move but you can't see it on screen until you let go of the drag.
The only way to get it back is to close SE completely.
When the file is reloaded I do a forced update of the views (CTRL+SHIFT+ Update View) and any dimensions that disappeared will reappear at the bottom left (origin) of the drawing - they can then be deleted.
This is not confined to one drawing, one user or one worksation - it's a general problem.
Does anyone else suffer from this because it's driving me nuts.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
RE: ST3 Re-attach dimension problems.
Can't say that I have seen that yet...and I do say yet.
-av8errr
Solid Edge ST3 MP5
xw4600
3GB RAM
Core2Quad CPU 3.00GHz
NVIDIA Quadro FX4800
