rosemount 1151 AMBIENT TEMPERATURE EFFECT?
I have read the rosemount 1151 product data sheet and came across some temperature effect & temperature limitation issues, what I'm stuck on is the difference between definitions, for example you can see link below is the graph That I would like to make but don't know where to start, appreciate it if someone can provide some help. thanks.
http: //files.en gineering. com/getfil e.aspx?fol der=ffbd15 8b-0289-44 70-a80d-8c a9be9fa289 &file= 1151-2.png
http:
RE: rosemount 1151 AMBIENT TEMPERATURE EFFECT?
Many great choices exist with the same Emerson company and hot choices among 3051 and 3095 (multi-variable) type models.
