Basketball court SOG thickness
SOG for a BB court in a community center (supposed to be HighSchool grade BB court)with proper flooring:
I have used 4" thick SOGs for autoshops without problems so I think a 5" thick slab should work fine. Any input from folks here would be great.
RE: Basketball court SOG thickness
http://w
Welcome back, been a while since I have seen a post of yours.
I would think that a 5" slab will do the job, however if PT is local and affordable I would consider this just to remove the joints.
How could you do anything so vicious? It was easy my dear, don't forget I spent two years as a building contractor. - Priscilla Presley & Ricardo Montalban
