Thermal expansion relieving flow rate and DP consideration
Dear Sir/Madam
sorry to bother your all this trivial.
Thermal expansion relief valves are required in liquid-full systems if the system can be blocked in and/or subjected to heat input from the atmosphere or process that results in overpressure.
The question is below (please see attached file):
Q1.PSV set pressure should follow the Design pressure for the equipment protected (in this example HX DP= 22 kg/cm2g) or follow the downstream header pressure design pressure(in this example
hot oil return header = 11kg/cm2g)
Q2.This HX located around 7 m so is the fire case scenario should be consider or thermal expansion scenario case should be considered ? But, in this example, the fluid is hot oil and it should not vaporized
so fire case may not be in the consideration. Am I right?
Q3. About thermal expansion case, is the method in my post attachment appropriated right or not?
Thank you so much.
Thank you so much.
