Machine shop responsibility to comply with "Industry Standard".
I'd like to get everyones take on an issue. If a machine shop gets a print with no GD&T on it as well as no reference to any dimensioning standard, how much responsibility does a machine shop have to catch any unspecified tolerances. For example: a 3 foot long rail with various slots and holes along the length has about .020" of bow in it. Is this something a machinist should have made a special effort to avoid in the absence of any other information or should this part be considered "to print" and called good?
The kickback I'm getting from the customer is that "Industry Standard" dictates that that straightness tolerance should be the same as the tightest tolerance in the default tolerance block. I've heard this before but I thought in modern times, industry standard had fallen by the wayside since it's not documented or enforceable.
Looking forward to the feedback...
Powerhound, GDTP T-0419
Engineering Technician
Inventor 2010
Mastercam X5
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
RE: Machine shop responsibility to comply with "Industry Standard".
That said, I have worked in a lot of shops where certain expectations of their suppliers had been evolved over many years of working together, and were never recorded, but were understood. I learned of the existence of these unrecorded agreements when some idiot MBA arrived and unilaterally changed the relationship without full knowledge or understanding of the change's impact, and I got nominated to clean up the resulting mess.
This sort of thing almost always happens when said MBA changes suppliers, i.e., sends an old (and technically incomplete) print out for bids, then goes with the lowest bidder. ... who of course does not include money or time to cover unstated requirements, and the first pieces come in 'to print, but wrong'.
Personally, I have never heard of any industry standard relating straightness or camber to any detail tolerance on the print. Industry standards for camber with which I am acquainted typically refer to the part length, stock length, and/or some linear dimension of the section, but not to a tolerance on either.
Mike Halloran
Pembroke Pines, FL, USA
Matt Lorono, CSWP
Product Definition Specialist, DS SolidWorks Corp
Personal sites:
Lorono's SolidWorks Resources & SolidWorks Legion
Inventor 2010
Mastercam X5
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
Frank
However, when I draw a part straight, I don't expect it to arrive noticeably cambered.
When it does, I'm thankful for the nitpickers on my team who provided a documented explicit chain of requirements back to, e.g. a specific industry standard for camber of straight bar stock, if not a tolerance or a note on the drawing.
Of course, after the MBAs arrive, the nitpickers are removed as unnecessary, and the survivors are pushed to take up the resulting slack, so stuff gets left off the drawings, and the shop guys start talking about the way things used to be.
Mike Halloran
If this is a customer/account you want to keep, can you suggest a method to straighten the rails to comply with their
requirementsdesires, and (having fixed their problem) then politely suggest putting a straightness requirement in a note, or (gosh what a great idea) by GD&T.RE: Machine shop responsibility to comply with "Industry Standard".
Chris
SolidWorks 10 SP5.0
ctopher's home
SolidWorks Legion
Inventor 2010
Mastercam X5
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
Frank
Inventor 2010
Mastercam X5
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
Technically it's the engineer/designer/drafter's responsibility to provide an unambiguous drawing, but the best results occur when the manufacturer is an active part of the process, not just passively taking what drawings come their way and interpreting (or ignoring - a problem I've also seen) them in a vaccuum.
.020, unless the rail is very short, isn't a lot so to even expect the machinist to have asked for the missing info is pushing it.
Not sure exactly what industry but I've never heard that one about the smallest tol in the block tol.
If only they'd invoked 14.5 with it's rule 1, depending on the thickness tol this may have achieved what they thought they were asking for.
As to response, that comes down to how much you value this customers business by the sounds of it.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
And to Tick's comment, well, yeah I've paid for my mistakes too.
Matt Lorono, CSWP
Personal sites:
Stuff looks like it was intentionally made as bad as our less than perfect prints will allow.
Time to talk to the boss about virtues of standards, tolerances, etc., etc., etc.,... again.
Let me join the Chorus singing "There is no such thing as "Industry Standard"".
Nowadays Craftsmanship is "what you can get away with".
Inventor 2010
Mastercam X5
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
The trick is to conceal all those costs until you have cashed out.
The easiest way to conceal costs is to dispose of the people who become aware of them.
Thus endeth the lesson.
Mike Halloran
The newest edition of ISO 1101 issued in 2011 states in paragraph 5.3 "Definitive drawing principle" that:
"The drawing is definitive. All specifications shall be indicated on the drawing using GPS [GD&T] symbology (with or without specification modifiers), associated default rules or special rules and references to related documentation, e.g. regional, national or company standards. Consequently, requirements not specified on the drawing cannot be enforced."
I gave pmarc a star.
Could somebody quote equally short, but powerful statement from ANSI/ASME?
I am preparing a memo for my boss
I wonder if there'd be anything in the inspection standard, but I'm not optimistic.
I didn't see anything in 14.100 with a quick look.
Is this actually a case where even I might think Iso is more appealing than ASME
I'm with you Ken; could there actually be something in ISO that I like better than ASME? Whoda thunk it?
Inventor 2010
Mastercam X5
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
* American Association of State & Highway Officials (AASHTO)
* American National Standards Institute (ANSI)
* American Society for Testing and Materials (ASTM)
* Institute of Electrical and Electronics Engineers (IEEE)
* National Fire Protection Association (NFPA)
* Society of Automotive Engineers (SAE)
* Underwriter Laboratories (UL)
We transferred the production of machines from Europe to the US, incl. all prints and found everything made to DIN. Bought a few DIN books in English and the rest was easy.
I do not see a problem in having different standards issued by different organizations as long as the standards are complementary and do not collide one with the other.
ISO is literally one organization but actually divided to different (about 200) Technical Committees (TC) which act like different organizations but behind the facade of ISO. Not sure how DIN looks like but I suppose quite similar.
The process is happening dynamically "as we speak". If you look thru catalogs of big suppliers like McMaster-Carr, some of their "DIN" fasteners refer to already non-existing standards and are in fact "ISO".
Similar trend can be seen everywhere as EN ("Euro Normen") and BS (British Standard) just copy ISO verbatim and adopt as national standards.
Jim Sykes, P.Eng, GDTP-S
Profile Services www.profileservices.ca
TecEase, Inc. www.tec-ease.com
I'd argue that strictly speaking without somehow referencing the spec that controls the 'stock' sizes, that just saying 'STOCK' alone doesn't cut it as a full definition. That's what I mean by 'complete material call out' - not just the grade but relevant standard that the bar or whatever is to.
That's what we did back in the UK for aerospace/defence stuff and I think I've seen similar for US defense etc.
That said, I'm guilty of that crime here, just saying '6061-T6' or similar and then having 'STOCK' next to a material thickness or similar. I could try to excuse it by saying that I only do it on 'non critical' dimensions or similar but arguably it's still incomplete.
Tips on Designing Cost Effective Machined Parts
This has been linked here before. One of the points the author makes is that he has to sell parts. If they look crappy, or you (or your puchaser) are unhappy, he will not be making any more sales. This imposes some discipline on the fabricator.
On the other hand, if you specify that your part is to be fabricated as per drawing 123-456, and drawing 123-456 calls up ASME Y14.5-2009, and you call up fabricatable tolerances, there is no need for the concept of Industry Standard.
Your link is really good and addresses a lot of issues that I've seen in the past, it doesn't address form at all though. I was sure hoping it would.
I certainly agree that the fabricator should make every effort to produce a part that the customer will gladly buy. A lot of prints I've seen don't even have a surface finish callout but that doesn't necessarily mean it's okay to have a horrible, hacked up surface finish. I know the idea is to make something that the customer will want to buy again or at least provide a service that they will be willing to pay for again. It's the unspecified, yet marginal issues that I'm really asking about. I don't believe having a straightness error of .020" over 36" is unacceptable, especially when there is no indication on the print that any thought was given to tolerances. Every dimension, and I do mean EVERY DIMENSION, is a 3 place decimal which is +/-.005 in the tolerance block. This rail had holes and other features on it. Having Y14.5 specified would have automatically limited the straightness error to .010 but who's to say that would have even been too much since no thought was given to the tolerances at all?
Anyway, I think I'm on the same page as most others here. It's not as easy as saying "too bad, you should have specified it." That might be true, but it won't win me any repeat business. It's such a slippery slope...:(
Inventor 2010
Mastercam X5
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
My big experience with crappy drafting was a manufactured product. We got to the point where there was one machine shop who knew how to make all the parts. He responded to compaints. He logged the phone calls. He could make the system work.
If he had gone out of business, it would have taken years for another shop to get up to speed.
Probably true, powerhound. I am lucky to have a good number of suppliers who work with me to get us what we want. They call all the time (read to some = "annoy me") to question me about tolerances and "what we really want" vs. what the drawing says. Sometimes we catch errors in the print, sometimes they just need clarification of how the parts work and how we measure the given feature, etc. And when it don't fit, I take the blame when it's my fault. That way, I can slap them silly when THEY screw up and fail to call me right away so we have a shot at salvaging the material.
As a engineer and/or designer or the part its your responsibility to define what you need. Suppliers are not mind readers. In other words do your job and if you screw up admit it dont try and stick the supplier with the bill.
I can tolerate ignorance long before I can laziness. Most of the time its laziness and then its blamed on the supplier to some unknown industry standard.
As for working with the customer if they are always quick to throw the mistake on you they will cost you more money than you will make.
Is that taken as a given or could someone legitimately argue that the part is not undersize it is just not hot enough?
Inventor 2010
Mastercam X5
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
I send a PO to Billy Bob and Cousin Elmo's machine shop. I want my part number 123-456 fabricated as per my drawing, coincidentally named 123-456. My drawing states that my dimensions and tolerances are to be interepreted to ASME Y14.5M-1982.
What does this mean?
- My PO is equivalent to a contract.
- The PO calls up my drawing 123-456, so my drawing is part of a contract.
- My drawing calls up ASME Y14.5M-1982, so the ASME standard is part of the contract.
A note on my drawing stating that the work "must meet quality workmenship standards" has no meaning unless the standard is explicitly identified. Perhaps it is my in-house standard, in which case, I have to pass a copy on to Billy Bob and Cousin Elmo, and perhaps, provide training in it.This is a big picture issue. So many people out there have a "generate drawing" process. They do not understand or care that someone out there has to order parts from the drawing, and write a meaningfuly PO. Several others, including your inspector, have to read the drawing and interpret it correctly and consistently.
