NXOpen Create New revision with VB2010/TC/NX7.5
Hi, i'm creating a .DLL in VB2010 to use it with File-> Execute-> NXOpen that will do a couple of things, it's a windows form that receives user inputs, mainly part numbers to create and do operations on them, operations like creating new part files in TC, import .dxf files, work with layers, create some curves, extrude, and create assemblies(In case someone needs help with one of the above perhaps i can help). So far i've been able to tackle all the problems i've found either with journaling or the NXOpen .Net API Reference, but this time i can't figure out this one.
The application needs to be able to create either new part files in TC(done) or create new revisions of existing part numbers, this one is the problem right now.
This is how i create the new part files:
Dim PC_UserName As String = Environment.UserName.ToString
Dim partFromTemplateBuilder1 As PDM.PartFromTemplateBuilder
Dim fileNew1 As FileNew
Dim databaseAttributeManager1 As PDM.DatabaseAttributeManager
Dim nXObject1 As NXObject
partFromTemplateBuilder1 = theSession.Parts.PDMPartManager.NewPartFromTemplateBuilder()
fileNew1 = theSession.Parts.FileNew()
theSession.PdmSession.SetDefaultFolder(PC_UserName.ToString & ":Newstuff")
partFromTemplateBuilder1.CreatePartSpec("Part_DPH",
txt_pcb3d_partNumber.Text.ToString, txt_rev_pcb3d.Text.ToString, "master", "")
databaseAttributeManager1 = partFromTemplateBuilder1.NewDatabaseAttributeManager()
databaseAttributeManager1.SetAttribute("DB_PART_NAME", "X")
databaseAttributeManager1.SetAttribute("DB_PART_DESC", "Y")
databaseAttributeManager1.StoreAttributes()
databaseAttributeManager1.Dispose()
Try
' The selected template doesn't exist
fileNew1.TemplateFileName = ""
Catch ex As NXException
ex.AssertErrorCode(3815003)
End Try
fileNew1.Application = FileNewApplication.Modeling
fileNew1.Units = Part.Units.Millimeters
fileNew1.NewFileName = "@DB/" & txt_pcb3d_partNumber.Text.ToString & "/" & txt_rev_pcb3d.Text.ToString
fileNew1.MasterFileName = ""
fileNew1.UseBlankTemplate = True
fileNew1.MakeDisplayedPart = True
nXObject1 = fileNew1.Commit()
fileNew1.Destroy()
partFromTemplateBuilder1.Dispose()
I thought that i could create new part revisions just by giving a higher revision value than the actual, but this results in the error: "Part with given part number exists in the database".
Last thing i tried was the PartFromPartBuilder which states:
The operation that this builder supports is equivalent to the file save as operation which can:
1.Copy a non-master dataset into a previously existing item revision,
2.Save a master dataset (and possibly non-master datasets) into a new revision of the same item,
3.Save any master or non-master dataset as a completely new item.
Which i think the point number 2 is the one i'm aiming, but i still can't figure out how to. I can save an existing part as a new item in TC(point 3), but when i try to create a new revision i keep getting the error: "Part with given part number exists in the database".
Can someone tell me if i'm missing something? or this ain't the way to achieve my goal?
L.B.D.
Try
End Try
fileNew1.Destroy()
L.B.D.
RE: NXOpen Create New revision with VB2010/TC/NX7.5
Dim ufs As UF.UFSession
Dim partTag As NXOpen.Tag
ufs = UF.UFSession.GetUFSession
ufs.Part.[New]("@DB/" & txt_sub_partNumber.Text.ToString & "/" & txt_rev_sub.Text.ToString, UF.UFConstants.UF_PART_METRIC, partTag)
