100 amp breaker tripped
We have a 50 HP motor at 480 v that is serviced through a 100 amp CB and VFD controlled. It runs a large fan that exhausts fumes from one department into a Regenerative Thermal Oxidizer to "cook" off the fumes before they are released to the atmosphere. I got a call from the second shift supervison that the fan had shut down because the breaker had tripped there was no damage to the motor or anywhere in the electrical pathway to the motor. Power is generated here locally in town, I suggested they had a low voltage condition causing the breaker to trip, they denied it. Am I correct in my assumption?
RE: 100 amp breaker tripped
That's what I'm trying to find out
Bill
"Why not the best?"
Jimmy Carter
