system materials
system materials
system materials
Hi everybody I have used other systems where you can colour a model to its actual material colour (I am using NX4 which has system materials, brass, copper etc) how do I apply these to models.
Thanks for any ones help,
Andy.
RE: system materials
You can drag (click and drag) the materials to your model. Then you need to render the picture. View - visualization - High quality image. You can use this in single parts or in assemblies. One side note after rendering the image you cannot rotate or move the part.
And the materials will remain in your part file, but the will only be visible after rendering.
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
