thin walled tube
thin walled tube
Is the calculation for tube thickness with a negative internal pressure the same as for posative internal pressure(pd/f). Can't remember this one and all texts only do formulaes for posative internal pressures, nothing showing an external pressure.
Cheers
Mick
Cheers
Mick
RE: thin walled tube
This formula is the same. The p is just the pressure difference. Fact is though, that you will have to check stability against imploding as well. For this a different criterium is necessary. I haven't got that in my active mmemory, but you should check a technical handbook or the internet on that. In german the term is "beulen" in english I do not know.
Karel Postulart, The Netherlands
Nuon Power Generation
We are more connected to everyone in the world than we've ever been before, except to the person sitting next to us. Lisa Gansky
