Steel making plant air conditioning, design guides
I will design a steel making plant air conditioning system and I need some advices about: the kind of equipment, fresh air, filters, ventilation, etc. Or where I can find information about this issue
Gracias
Gracias
RE: Steel making plant air conditioning, design guides
My other concern is about the suppliers, Do I need to know an unkown company (I'm at South of the border, mostly Trane, Carrier and York and that's it)
About ASHRAE, I couldn't find specifical information
Anyway, thanks and regards
Control rooms HVAC needs positive pressurisation of atleast 10pa to keep the dust out.So no of doors,windows etc (leakage area) will drive fresh air requirements.Electrical rooms also will need pressurised and filtered ventilation systems.Water cooled systems with dedicated cooling towers are preferred due to dusty environment.Do not tap into plant wide cooling water systems as they may be running at higher temperatures than you would require.Specify wide fin spacing for AHU coils.
