Acid Resistant Plastic Sheet Material
Hello, first time user here.
I am currently designing a Sulphuric Acid Tank (98%), which is located inside an Acid Plant building. In case of a pinhole leak, which could squirt over the containment wall and hit an operator, I need to provide a "splash guard". I have envisioned a plastic curtain hanging from the top of tank, but do not know which type of plastic to apply. The concept would be similar to the curtain you see for walk-in refrigerators, with multiple overlapping strips of plastic. It will need to be able to resist the acid, withstand a max temperature of 200 F, and (of course) I am looking for the most cost effective solution.
If you have any suggestions, or know of a good supplier to contact, please let me know. Thanks in advance.
RE: Acid Resistant Plastic Sheet Material
PVC is good for sulphuric acid.
Your problem will be a clear flexible plastic that can withstand 200F.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
You might want to check with someone like: http:
or http://www.lmairtech.com/products_fume_hoods.htm
or any similar company, of which there should be tons.
TTFN
Chinese prisoner wins Nobel Peace Prize
