How to calculate vaccum performed by a centrifugal pump in sucction?
A centrifugal pump (not a vaccum pump) when fully filled with liquid is able to produce a certain negative pressure (vaccuum) at succion line. How can I determine this vaccum?
If the succion line is connected to a tank with no vent line, and the pump is turn on it's possible to collapse the tank.
Again: how can I calculate the vaccum exerted over the tank?
The pump's head is 60m (flow rate = 45 m3/h).
I hope you understand my question...
Thanks a lot
RE: How to calculate vaccum performed by a centrifugal pump in sucction?
For your purposes it is best to assume 30 inHg, or the vapor pressure of your fluid.
I would agree, without having any definite information on the particular pump use the above info as the safest option.
I would look for some data-sheets on your pump in question, this should be all cataloged information from your supplier. Surely the pump is rated to a certain specification? Suction line pressure is also going to be variant depending on how you have your fluid transfer lines installed, size of tank, amount of product etc... I would start by trying to spec up your pump first, then look at the pipe runs and suction feed with regards to tanks and weights.
___________________
www.airpumping.co.uk
You pour it - we'll pump it!
Pumps don't suck. Atmosphere pushes.
