pipe schedules and wall thicknesses
can any one tell me why in some plant designs, the piping is designed using schdule and in the same plant, other piing is designed using wall thickness?
RE: pipe schedules and wall thicknesses
http://en.wikipedia.org/wiki/Nominal_Pipe_Size
Mike Halloran
Pembroke Pines, FL, USA
rmw
Dan T
They could just as easily specify "SCH XXX minimum"...
SNORGY.
That said, I generally use schedule instead:)
Mike
Oilfield applications are typically nominal OD and wall weight. Valves use piping schedule as do plants and mainline transportation systems. Pretty much all the same, some variance due to commercial availability and desired material needed to custom suit the application.
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
rmw
