Export to AutoCAD using Visual Basic
I'm trying to write a routine in Visual Basic to export Pro/Engineer drawings to AutoCAD but I can't find the correct command for this and I can't discover how to run map keys from code.
The VB command are the same as JLink as far as I can tell.
I can open loop through drawing files in a folder and erase them from session without any problem but I can't save/publish/export to dwg.
Does anyone have any experience in this?
RE: Export to AutoCAD using Visual Basic
This is going back a long time for me, but I once set up a routine in Pro/Batch that was executed from command-line scripts.
Pro/Batch allowed me to to DWG/DXF + PDF exports all in one go. I didn't use visual basic (I just used DOS *.BAT files), but you should be able to do the same from a VB routine.
Try doing a search here and elsewhere for Pro/Batch stuff. Unfortunately, my brain has taken an early friday and I can't recall any details.
I figured it out, this outputs dxf but when I've opened them they appear identical to the dwg files created when I use Publish->DWG from the ribbon in Creo (wildfire 5)
I took a lot of the code from the VB parameters example that can be found in the loadpoint
There isn't a great deal of error handling as I only need it to work once but maybe someone can improve on it.
CODE
Imports pfcls
Imports System.IO
Public Class User_Form
    Dim asyncConnection As IpfcAsyncConnection = Nothing
    Dim dValue As Double
#Region "Form Events"
    'Function   :   FormPD_Load
    'Purpose    :   Event handler to check if required environmental
    '               variables have been set and name server is running
    Private Sub User_Form_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
        Dim errMsg As String = ""
        If Not System.Diagnostics.Process.GetProcessesByName("nmsd").Length > 0 Then
            errMsg = "Name service is not running on the system."
        End If
        If System.Environment.GetEnvironmentVariable("PRO_COMM_MSG_EXE") = "" Then
            If errMsg = "" Then
                errMsg = "Environment variable 'PRO_COMM_MSG_EXE' has not been set."
            Else
                errMsg = errMsg + Chr(13).ToString + "Environment variable 'PRO_COMM_MSG_EXE' has not been set."
            End If
        End If
        If System.Environment.GetEnvironmentVariable("PRO_DIRECTORY") Is Nothing Then
            If errMsg = "" Then
                errMsg = "Environment variable 'PRO_DIRECTORY' has not been set."
            Else
                errMsg = errMsg + Chr(13).ToString + "Environment variable 'PRO_DIRECTORY' has not been set."
            End If
        End If
        'Set the opening status of the buttons
        Me.ctl_Connect.Enabled = True
        Me.ctl_Disconnect.Enabled = False
        Me.ctl_Convert.Enabled = False
        If Not errMsg = "" Then
            errMsg = errMsg + Chr(13).ToString + "These may lead to errors in running the application."
            MsgBox(errMsg, MsgBoxStyle.Critical)
        End If
    End Sub
    'Function   :   FormPD_FormClosing
    'Purpose    :   Event handler to disconnect from Pro/E if aldready
    '               connected.
    Private Sub User_Form_FormClosing(ByVal sender As Object, ByVal e As System.Windows.Forms.FormClosingEventArgs) Handles Me.FormClosing
        If Not asyncConnection Is Nothing AndAlso asyncConnection.IsRunning Then
            asyncConnection.Disconnect(1)
        End If
    End Sub
    'Function   :   btnConnect_Click
    'Purpose    :   Event handler to connect to existing Pro/E session.
    Private Sub ctl_Connect_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ctl_Connect.Click
        Try
            lblStatus.Text = "Connecting..."
            Me.lblStatus.Refresh()
            Me.Cursor = Cursors.WaitCursor
            If asyncConnection Is Nothing OrElse Not asyncConnection.IsRunning Then
                asyncConnection = (New CCpfcAsyncConnection).Connect(Nothing, Nothing, Nothing, Nothing)
            End If
            'Re-set the status of the buttons
            Me.ctl_Connect.Enabled = False
            Me.ctl_Disconnect.Enabled = True
            Me.ctl_Convert.Enabled = True
            lblStatus.Text = "Connection established to Pro/Engineer Session"
        Catch ex As Exception
            MsgBox(ex.Message.ToString + Chr(13) + ex.StackTrace.ToString)
            End If
            lblStatus.Text = "Error occurred while connecting to existing Pro/E Session"
        Finally
            Me.Cursor = Cursors.Default
        End Try
    End Sub
    'Function   :   btnDisconnect_Click
    'Purpose    :   Event handler to disconnect from existing Pro/E session
    Private Sub ctl_Disconnect_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ctl_Disconnect.Click
        Try
            lblStatus.Text = ""
                lblStatus.Text = "Connection to Pro/Engineer Session terminated"
            Else
                lblStatus.Text = "No Connection is present to any Pro/Engineer Session"
            End If
        End Try
    End Sub
#End Region
    Private Sub ctl_Convert_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ctl_Convert.Click
        'Start by checking to see if the folder text boxes are set
        If Me.txtProEFolder.Text.Trim.Length = 0 Then
            MessageBox.Show("The ProE Folder is not set", "ERROR!", MessageBoxButtons.OK, MessageBoxIcon.Exclamation)
            Exit Sub
        End If
        If Me.txtAcadFolder.Text.Trim.Length = 0 Then
            MessageBox.Show("The AutoCAD Folder is not set", "ERROR!", MessageBoxButtons.OK, MessageBoxIcon.Exclamation)
            Exit Sub
        End If
        'Check that both folders exist
        If Not IO.Directory.Exists(Me.txtProEFolder.Text.Trim) Then
            MessageBox.Show("The ProE Folder specified does not exist", "ERROR!", MessageBoxButtons.OK, MessageBoxIcon.Exclamation)
            Exit Sub
        End If
        If Not IO.Directory.Exists(Me.txtAcadFolder.Text.Trim) Then
            MessageBox.Show("The AutoCAD Folder specified does not exist", "ERROR!", MessageBoxButtons.OK, MessageBoxIcon.Exclamation)
            Exit Sub
        End If
        'Set the working directory of Pro/E
        asyncConnection.Session.ChangeDirectory(Me.txtProEFolder.Text.Trim)
        'Collect the list of files in the ProE Folder
        Dim strFileList As String()
        strFileList = IO.Directory.GetFiles(Me.txtProEFolder.Text.Trim, "*.drw.*")
        'Declare a list of drawings
        Dim strDrawingList As New ArrayList
        'Loop through the list collecting a list of all drawings
        For Each strFileName As String In strFileList
            'Collect the drawing name without the path or the last integer
            Dim strDrgName As String = strFileName.Remove(0, Me.txtProEFolder.Text.Trim.Length + 1)
            strDrgName = strDrgName.Remove(strDrgName.IndexOf(".drw.") + 4)
            'Add to the drawing list if it doesn't already exist
            If Not strDrawingList.Contains(strDrgName) Then
                strDrawingList.Add(strDrgName)
            End If
        Next
        'Declare counter objects for the progress bar
        Dim iItemIndex As Integer = 0
        Me.ProgressBar1.Maximum = strDrawingList.Count
        Me.ProgressBar1.Minimum = 0
        Me.ProgressBar1.Value = 0
        'Loop through the list and open the drawing
        For Each strNextDrg As String In strDrawingList
            'Update the current drawing label
            Me.lblCurrentFile.Text = "Current Drawing: " & strNextDrg
            Me.lblCurrentFile.Refresh()
            'Increment the item index
            iItemIndex += 1
            'Create a model descriptor
            Dim myModelDesc = (New pfcls.CCpfcModelDescriptor).CreateFromFileName(strNextDrg)
            'Open the drawing
            asyncConnection.Session.OpenFile(myModelDesc)
            'Collect the model
            Dim myModel As IpfcModel = asyncConnection.Session.GetModelFromFileName(strNextDrg)
            'Construct the file name
            Dim strFilePath As String
            strFilePath = Me.txtAcadFolder.Text.Trim & "/" & strNextDrg.Replace(".drw", ".dxf")
            'Create a DXF export instruction
            Dim myDXFInstr = (New CCpfcDXFExportInstructions).Create
            'Export the drawing to dxf
            myModel.Export(strFilePath, myDXFInstr)
            'Delete the log file in the autocad output folder
            IO.File.Delete(strFilePath.Replace(".dxf", "_dxf__out.log.1"))
            'Erase the drawing and all associated models that have been placed in session
            myModel.EraseWithDependencies()
            myModel = Nothing
            'Update the progress bar
            Me.ProgressBar1.Value = iItemIndex
            Me.ProgressBar1.Refresh()
        Next
        'Inform the user
        MessageBox.Show("Process Complete", "Pro E to ACAD", _
    End Sub
End Class
