need motor for small wind tunnel, 0-10,000rpm, 12A, 4-8" dia,
need motor for small wind tunnel, 0-10,000rpm, 12A, 4-8" dia, controllable. Must be able to sustain speed of fan/turbine. Have not found fan or turbine/fan to attach to motor. Motor fan combination will pull 0-9000 fpm of air thru small 5' length wind tunnel with 4" square test chamber.
RE: need motor for small wind tunnel, 0-10,000rpm, 12A, 4-8" dia,
Is a VF drive applicable to this? In [maybe too] simple terms, with 240Hz input, isn't a 2-pole motor good for 14,400 rpm?
Don
Subvert the dominant paradigm... Think first, then act!
http://www.thomasregister.com
and type Motor under Product or Service which will return many motor categories and links to their manufacturers. E.g.
Air Turbine Technology Inc.
1225 Broken Sound Pkwy., N.W., Suite D
Boca Raton, FL 33487
USA
Tel: 800-840-4019
Fax: 561-994-8097
http://www.amc-inc.com/vsrmotors.html
