Variable vs. Constant Springs and PTFE Low Friction Plates Application
Dear Colleagues
Please kindly share your expert opinion on application of Variable vs. Constant Springs and low friction TSP (PTFE) plates in combination with springs:
1.    What variability/vertical travel of variable spring support is generally acceptable in front of static equipment (tanks, vessels. etc) subjected to settlement or thermal expansion?
2.    Is there a variability or/and vertical travel threshold when a variable spring in vicinity of equipment is not considered as a good engineering practice and application of constant spring is required to keep the nozzle load within allowable?
3.    What magnitude of horizontal movement of the shoe on a spring can load flange requires using TSP to reduce a lateral force on a spring?
4.    What magnitude of horizontal movement may be considered for modeling spring as frictionless in CII and what horizontal movement on a spring load flange requires modeling spring with friction to calculate true nozzle loads.
5.    Does physical location of the TSP (inside or outside the building) effects/limits TSP application? Would any of these locations be a preference or otherwise for using TSP in oppose to regular CS shoe?
Thanks a lot for your time and expertise!
Vikoll
