Steel Connection Design
Looking for a good book with extensive examples for steel connection design.  I currently have the LRFD Steel Design 3rd Edition, which works well.  Any other suggestions?
Thank you for your help,
Derek
RE: Steel Connection Design
I have this one:
Handbook of Structural Steel Connection Design and Details
Ackbar R. Tamboli, P.E. FASCE, Editor
McGraw-Hill
(c)1999
ISBN 0-07-061497-0
It has lots of great connection details with line drawings.
The AISC 13th edition comes with the CD called "AISC Construction manual companion v13.0" and included on this is a series of AISC design examples. This will have most of what you will find published anywhere else.
They currently offer it in PDF for Free here  -  http://www.aisc.org/content.aspx?id=24314
If you need HSS connection you can get the AISC HSS design guide #24
Perfect.  Thank you both for the references.  This is exactly what I was looking for!
