Routing Issue
Routing Issue
Routing Issue
A former employee converted cables in to imported objects. Now I can edit route spline but the cable itself remains. Is there a way to convert them back.
RE: Routing Issue
An imported object can only be created by importing it into a part or assy. A part cannot be converted into an imported part, however the feature recognition module (FeatureWorks) can create a regular part from an imported part.
RE: Routing Issue
Understood, but this converted back to where the original 3dsketch will be associated to it?
