subsea power cable / FOC
How generally is possible realize a conjunction between a subsea power cable(or FOC) and a terrestrial cable??(by only a junction box??)
Wich are the main parameters to consider for the design??
thank you all the community!
RE: subsea power cable / FOC
For Medium Voltage Power Cables you could use a cable joint. See, for instance:
Raychem Terminations and Joints
http://www.gvk.com.au/pdf/raychem_hvlv.pdf
For FOC cable you need a junction box as the fiber optic connectors have to be enclosed and accessible.
