I NEED HELP FROM SOMEONE THAT KNOWS JOURNAL FILES AND VB
I am working with NX-6 6.0.4.3 for 64bit XP Windows, I mostly work on large assemblies about 10.000-30.000 components with about 600-1000 drawing -sheets. I have major problem when I want to change the machine-codes, clients name, date, designer name, cad number at the template of the drawings, also I have problems with pdf 's exports of the drawings because until now it wasn't necessary to export them. Now I have to make pdf for each drawing that I give to production. Also now it is asked from me to make an excel file with the commercial materials that I use in every drawing. I think that my problem will be solved with journal files. The problem is that I have made a lot of macros but I never practice with journals (I don't have any experience in journal or in vb)
Some details that maybe help you to understand my problem and what I want to do:
First the drawings for each assembly that I use are non master part drawings.
Second when I change the notes from drawing template I use attributes that I insert them from expressions.
What I want to do: I need to declare the load options for the folder that I work and from this folder the NX to open only prt files that the name contains the word <<draft>>, when the files are open I want to change specific attributes, make an export to pdf with the name of part name and import the part list to excel.
Does anyone have an idea how to start?
Thanks a lot for your time to read me.
RE: I NEED HELP FROM SOMEONE THAT KNOWS JOURNAL FILES AND VB
www.nxjournaling.com
are there any other websites such as the one you have provided that would be useful as well.
Scott Copeland
Design Engineer
Persego Int'l
www.persego.com
Of course, you can post your question here at eng-tips. Also try out the search function; it works well and you can dig up some good example code that's been posted over the years.
I know a couple other forums, but only very rarely visit; so I can't comment on the quality you will find there.
There is a general NX forum at http://www.plmworld.org/; or at least I think there is, I can't find an obvious link to it now.
There are also UG/NX forums at http://www.mcadcentral.com/ug/forum/.
I've also seen an NX blog at http://nxway.blogspot.com/. This one is mostly random blog posts about NX features/tips/news. It appears that it hasn't been updated since mid-2010.
www.nxjournaling.com is only a few months old, so not much content there yet and some site features have yet to be implemented. If you have any comments/questions or ideas for journals that would appeal to a wide audience, please email them to info@nxjournaling.com
I'm sure I missed a few. Anyone else have links to share?
