VB macro for points insertion in stock
Hi all,
I want a VB macro, for inserting points in de middle of the faces
of a rectangular workpiece, as the photo attached. Select the stock execute de VB and points insertion.
And if its possible, in the middle of a circumference too, when I select the stock model.
Thanks.
RE: VB macro for points insertion in stock
The attached journal in the zip file (change .txt to .vb) will work for circular and rectangular/square faces.  The journal simply asks you to select faces.  The journal then checks that the face is planar.  If the face has one edge and it is circular then the centre point is created.  If the face has four linear edges then I have assumed they form a rectangle or square (not always the case but should generally be OK) then the journal creates its centre point.
The more general case of creating a planar outline centroid requires the following.
1) Make the face the work plane.
2) Create a boundary entity through the edges.
3) Use the boundary to determine the centroid.
4) Create the point.
To create the boundary (in a program) I would need to have a CAM license (which I don't have)
Hope this helps.
Frank Swinkels
Thanks Frank,
I was looking for this.
apa berri,eres el puto amo,estos giris solo saben comer donuts y se creen la polla,pero asi va el mundo,todo transgenico y superficial,siempre dependiendo de la puta gasolina,En fin,seguiremkos chuopandoles el culete a estos mamones,chao.
Hi Josemi,
You are the best jajajaja.
