Drawing border template
Good morning everyone,
I'm hoping someone can help with this, a drawing border template has been created and parts of it have been done using sketching. The problem is when I now go New-Drawing and select it when it appears on my screen the sketch is active.
Any thoughts appreciated.
RE: Drawing border template
Open the template , goto drafting module, close the sketch environment, SAVE the template.
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
I tried that but it still starts up in sketcher :(
I'm also getting another weird issue :( The template has attributes in like this (<W@DB_PART_DESC>) which work fine. However, when I add them to older drawings use File-Import-Part then selecting the template some of them go a bit strange (see below)
<WUGII-UGII-ANON-5.PRT@?BDR_TITLE2>
